跳转到主内容
Repair and disassembly information for Samsung's flagship S21 Ultra Android smartphone, released in January of 2021.
58 个问题 查看全部
Primary Microphone not working and SIM detection fails sometimes.
Hi,
One month ago I dropped my phone in pool and I took it to the service center where they have dried out the phone. Everything was working fine but later only I was able to find out that the primary microphone is not working and also sim doesn't get detect. So couple of times I did resetting the phone pressing the volume down and power button and that fixed the SIM related issue. After couple of weeks again there was an error saying SIM can't be detected and I tried the same solution , after several attempts it detected again. Then again after two days the issue pops up once again. So I was able to find out that primary microphone and SIM card slot is in the same daughter board and thought of replacing it by myself. I got the new board and replaced it yesterday and still my microphone is not working. What would be the solution ? Is there anything I need to check/replace further like flex cables and all ? Please advise. Appreciate your help.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
When it comes to liquid damage, you really can't repair it entirely. No matter how thorough you are, there will always be remaining damage that won't show up until later down the line.
Even in my shop I tell customers while I can sometimes repair liquid damage, there is absolutely NO GUARANTEE AND OR WARRANTY on the parts and labor. So if it dies the second they walk out the door, that's their problem unfortunately. Any repair shop would go out of business if they offered warranties on liquid damage repairs.
At this point, you might be better off replacing the device as you'll more than likely throw more money into fixing this one than buying a replacement.
这个答案有帮助吗?
得分 2
4条评论:
Thank you Jesse for your reply. I am going for a replacement.
完成的
Jesse, first common sense answer I've seen in a while. Nice one. 👍
完成的
@strongbow thanks!
完成的
my primary micropuhone does not work after rebuild -- everything else checks out on Samsung diagnostics.
完成的
添加一条评论
添加你的答案
Rahul Manayath 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 417
