跳转到主内容
主板和 CPU 维修指南。
Desolder and replace relay’s
Hi,
I am about to replace some relay’s on the PCB for a jacuzzi. The legs on the relay are a bit too far between to be able to melt the solder, equally on all pins, to remove the relay.
Any tip so I can melt the solder on all pins at the same time and remove the relay? I need to be sure not to overheat the PCB or other component’s.
See attached.
Regards
Bjørn
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi
From my experience your best 2 options are to do the following
1) use low melt solder (chip quick) to lower the melting point to the point where it will take 20-30seconds for the solder to set again
Or
2) use a hot air rework station to heat them all up at once ,the hot air is really good at desoldering all sorts of things but can melt plastic very easily so if you use this method to desolder something do it from the other side of the board to avoid meting the plastic and use kapton tape to shield and other sensitive things (eg more plastic or capacitors)
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Buy some solder wick and use that to draw solder out of the holes.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Bjørn H. Eide 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 321
