跳转到主内容
The twelfth and final generation of the Cadillac Eldorado was introduced in 1992 as a two-door coupé.
Floor shifter lights up wrong gear.
Transmission has been rebuilt. Shifts great! It just lights up wrong gear. Unless I can get the light in park (P) or neutral (N) it will not start. I need to bypass safety switch or fix whatever lights up gears.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It sounds like you may have 2 separate issues going on here. 1: your shift cable needs adjusted to show the correct gear. And 2: you need to check the safety switch. That should be mounted on the transmission, so the light indicating the gear shouldn't have an effect on that. Is it properly connected?
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jeffrey Frye 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 78
