跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
My screen is fuzzing with pixels and small numbers
Need help, my Imac stopped working mld use, initially whitce sceen, but when trying to rwboot pixels and intermittent numbers. No safe mode availableHave tried to fix..got install OS, but stalling
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
13条评论
Can you take a few pics of the screen with your phone so we can see what you mean 在已经存在的问题里加入图片
完成的
Have done now, thought I had done it
完成的
I believe it will be earlier model, no sign of any markings sorry!!
[image|2738913]
完成的
iMac 20 inch core 2 duo 2.66??
完成的
显示更多的8条评论
添加一条评论
1个答案
最有帮助的答案
Do you have access to an external display which you can plug in via DVI port on the system. Does it look clean? If it does then you have a bad display assembly and/or the displays data cable. If the image is the same then the logic boards GPU logic has an issue.
这个答案有帮助吗?
得分 3
4条评论:
Dan, I actually have no idea what version I have, so apologies for confusion caused, it’s an older model. Unsure if I can display externally sorry ?
Hopeless information, novice to this sorry :(
完成的
@scosser73 if you can place here SERIAL NUMBER (will be somewhere on iMac - https://support.apple.com/en-us/HT201634 ) by this we will know what model you have :) - not sure if it's 5K as the installation is for El Capitan (if I remember right) :)
完成的
Have no idea where serial number is as nothing to be seen on exterior of case
完成的
@scosser73 - The S/N is on the bottom of the foot, you can plug it into here EveryMac - Lookup let us know what you have and then we can move forward!
完成的
添加一条评论
添加你的答案
Scott McArthur 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 198
