跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
constant restore loop after logic board replace
after replacing the logic board the iPod boots to a white screen asking you to connect to iTunes and Restore. iTunes fails during the restore due to error 1416/1415. This happens in both Windows and Mac OS X (tried tiger, leopard and snow).
When I look at the partition via pdisk, it says that there is no valid block 1 on the device.
Do I have a bad hard disk or is there another fix I'm missing.
Richard
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Try unplugging all USB devices other than the iPod cable, keyboard and mouse. Sometimes when trying to do a restore other USB devices can interfere in the process. I that doesn't work then you should try to take it apart and replug all of the cables to make sure they all have a good connection. If that still doesn't work then it probably has a hardware problem. That would mean either the logic board, hard drive or possibly even the hard drive cable.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Richard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 1,777
