跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
147 个问题 查看全部
I replaced the screen and the power button quit working.
I have replaced the screen on my iPad 6 a1893 and the power button no longer works. The volume buttons still respond. So I orders a new flex cable. Plugged it in to test. Same issue, volume works and power button does not. Any advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hello! I believe the issue you are probably having is a board issue where the components for the power button may have been broken off or damaged. In the image of the iPad 6 logic board below, the components I circled in red to the left go the power/volume button zif connector are the components that control the power and volume buttons. Depending on which of these get knocked off, one of the buttons may stop working. I've accidentally knocked these off when cleaning the adhesive off of the frame of the iPad 6 before, it is very easy to do, but no so easy to fix, the components will most likely need soldered back into place.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jessica Gauthier 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 139
