跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Would snapping the Power/Volume button cable effect the iPod?
That may sound like a vague question, but let me explain. In replacing the screen on my 4th Gen iPod Touch, I was putting everything back together, I tested it, everything worked fine, and was about to screw the metal plate back on. In the process though, I somehow nicked the Power/Volume button cable right behind the Power button (above the rear-facing camera). It was a small tear, and I thought, well not the end of the world, I guess I just won't use that button.
So I disconnected the new screen to have a better look, and didn't see any other damage. All other cables intact, everything like it should be. But when I reconnected the screen to all the ports, nothing happened. The screen didn't respond at all. I reattached the damaged screen/digitizer cables, (since it actually worked, it was just cracked), and it didn't respond either.
So I'm wondering if that one cable controls power to the unit, or dictates more than I thought, other than Volume and the Power button. If it is that important, would soldering a new cable on fix everything, or is it possible I shorted the battery or something else weird? Any help is much appreciated! Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
If you have damaged this part - it may no longer power up
iPod touch (4th Gen) Volume/Power Cable图片
产品
$14.99
这个答案有帮助吗?
得分 0
添加一条评论
I broken this cable and now i can't lock the ipod and change the Volume,
for power up no problem, you can charge it and automatically it power up..
for lock the ipod you can use Activator..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matt Pascucci 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,594
