跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
20 个问题 查看全部
Increasing storage capacity SE
Will increasing the storage capacity of 16GB iPhone SE 1st Gen to 32GB affect the performance or battery life in any negative way? Can it lead to unexpected shutdowns? I was planning to increase the storage to 32GB since 16Gb is too less for me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hello, Kunal.
While upgrading storage does not typically cause issues, in an iPhone it can definitely have unwanted consequences. Upgrading iPhone storage is a complex and lengthy procedure so it is not recommended especially for beginners.
这个答案有帮助吗?
得分 1
4条评论:
What are some of those unwanted consequences? I was planning to get it done from an unauthorised service centre as Apple does not allow it.
完成的
If you want to do it why not go 128 gb?
完成的
@Kunal Jain Possibly breaking the device. Since this is an SE first generation I just recommend upgrading especially since it isn't supported anymore.
完成的
From the research I have done on this, on the SE it is not possible to change the storage capacity from what it originally was when it was manufactured.
完成的
添加一条评论
添加你的答案
Kunal Jain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 370
