跳转到主内容
The Mi 11 is a flagship smartphone by Xiaomi with a 6.81" quad-curved AMOLED display, a 108 MP main camera, an in-display fingerprint sensor, and a 4600 mAh battery. It’s the first phone to feature the Qualcomm Snapdragon 888 and runs MIUI 12 over Android 11.
15 个问题 查看全部
Does anybody know this part?
Hello guys,
i need the part from the picture to repair my Mi 11 Ultra... it's a metal bracket / clip wich hold's the flex-cabel from the back-display on the mainboard. Does anybody know what's the exact name for this part, or can someboy tell me where i can buy it!?
Kind regards,
David
Update (09/15/2022)
I have found it, thanks guys!!!
If anybody need's the same part, here it is:
https://www.aliexpress.com/item/10050047...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
My educated guess is that this is the battery connector bracket. Mi 11 Screen Replacement guide has a similar part that is shown in step 9. I can't seem to find a place that sells it specifically, but I would be willing to bet that you could find it if you search eBay.
这个答案有帮助吗?
得分 3
1条评论:
Thanks for your information! Now I know the connector type is called "fpc" and I can search for it. Do you think it's possible to glue the connector on the mainboard or to stick it with a heat resistant tape?
完成的
添加一条评论
It's a clip to hold the fpc connection in place. As long as the connection is seated properly you could get away without it if you can't find another. Through normal use the connector shouldn't move unless the phone suffers a heavy drop.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Kuki 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 282
