跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。可選GSM/CDMA,eSIM/nano-SIM,64GB/256GB/512GB,銀色/金色/太空灰色。讀法是“iPhone Ten S"。
20 个问题 查看全部
İs it possible to upgrade iPhone XS cameras?
Hello, iPhone XS is really good phone, and i want to upgrade its cameras, i checked all iphone teardowns but i cant find solution, need help from experts Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Upgrade or replace?
完成的
Upgrade. İf 12 mini rear camera fits.
完成的
添加一条评论
3个答案
已选择的解决方案
Upgrading to a better phone would be easier. Nothing wrong with the camera as it is.
这个答案有帮助吗?
得分 0
1条评论:
Thank you for replying
完成的
添加一条评论
最有帮助的答案
Hi Talha
I'm not an expert but I believe upgrading XS camera is not possible the processor inside will process as the image as inbuilt and also the aperture won't get usual light.
这个答案有帮助吗?
得分 1
1条评论:
完成的
添加一条评论
Hi Talha,
@ds17 is correct; the cameras for each model of iPhone are custom built for that phone and that phone alone and will not work in another phone. There are differences in connector size and position as well as the camera mounting, and its unlikely that the phone's software would correctly recognize a different camera even if you were able to physically replace it. And we haven't even begun to address the new image stabilization hardware that comes with newer cameras.
So the short story is, no, iPhone cameras are not upgradeable. The closest you can get is to upgrade your phone to a newer model.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for replying.
完成的
添加一条评论
添加你的答案
Talha Kendir 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 172
