Is this a screen cable related issue?
I have similar issue. Is this a screen cable related issue?
Often I seen this issue when the chin plate has been damaged. Basically the cables which sit just under it get damaged. These cables feed the LCD with the needed signals or the display its self received a physical blow so the bonding of the data cables have become dislodged.
Sadly, in either case the repair is the same replacement of the display assembly MacBook Pro 15" Retina (Late 2016-2017) Display Assembly and he's the guide 2017年带Touch Bar的15寸 MacBook Pro 屏幕更换
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 90
2条评论
@vmv_86 - What is your exact system?
Different series had different causes.
由 Dan 完成的
@danj A1707 MBP 2017 15"
由 Vesa-Matti 完成的
