跳转到主内容
Repair guides and disassembly information for the Samsung Galaxy A51 Android smartphone. Released in January of 2020.
103 个问题 查看全部
How to save the data with a broken screen Samsung A51?
So I got the following problem, the phone got dropped from the 3rd floor and the screen is completely mashed. The phone still boots and is online, you can also use a mouse or keyboard to put in the passcode.
Now I want to save the data off the phone before I do any taking apart or such. How can I achieve that? I tried using the keyboard to put in the passcode and then plugging it in to my PC, however it needs to allow the PC before I am able to access the data.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
you can use a hub to mirror the image of the screen to a tv or monitor via hdmi
这个答案有帮助吗?
得分 1
添加一条评论
You need to enable usb debugging. Use your mouse to,
Go into settings then look for software information then find the build number.
Click on the build number 7 times and a pop up should say you are now a developer.
Click back into setting and click on developer options, scroll down to usb debugging and enable it. Go back to the Home Screen and try connecting your computer again.
这个答案有帮助吗?
得分 1
2条评论:
Well, I would do that, but I can't see anything on the screen so that is not possible, if it was I could also do it while connecting it to a PC.
完成的
So how do you put the passcode in if you can’t see anything? Try running smart switch and connect the phone. You might have to allow access which you can’t do. Last resort is Google adb android data transfer. Ball ache but it might help. Is it not backed up to your Google account online?
完成的
添加一条评论
添加你的答案
JSE 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 32
总计 721
