跳转到主内容
于2015年十月26日上市的第四代Surface Pro平板电脑。
209 个问题 查看全部
Removing the Display for a Surface Pro 4 with Glass Screen Protector?
I have a Surface Pro 4 tablet with a glass UAG screen protector that I want to replace the battery. I've removed the display on another Surface Pro 4 using a heating pad so I'm familiar with the process.
For the Surface with a screen protector, I planned on use several iOpeners to heat the edges to soften the adhesive.
Has anyone successfully performed the display removal on a Surface with a glass screen protector?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Just do it the same way as the last one. Which ever way you do it there’s always a chance the protector will come off anyway.
这个答案有帮助吗?
得分 0
2条评论:
My concern was not so much whether the protector would come off, but whether the thermal expansion between the LCD and the protector could crack the display?
完成的
Why not just remove the protector then work on the screen replacement?
完成的
添加一条评论
添加你的答案
David S. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 120
