Whats the use of flex cable
Hi good day may i ask whats the use of flex cable attached to mother board of beats pill 2.0 since i accidentally pull it and break it when i try to replace the battery.
Hi
Are you talking about the black one that is connected to both sides of the device ,if it is I believe that is a speaker cable and you most likely won’t get any sons if that’s the case
If it’s a different one use this amazing guide to upload some photos
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
Hi thanks for the reply. I am talking about the nfc flex cable that was stick underneath the battery. Will it still work even if its break already
It might work
The only things I could see not working is the NFC pairing and possibly Bluetooth
I would reassemble it and see what’s happening ,also try Bluetooth and a aux cable
If it doesn’t work here’s a link to a replacement part https://www.ebay.co.uk/itm/324107000331?...
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 120
