Why is my temperature gage not working
When I turn on my f150 the temperature gage shoots all the way up and stays there I replaced the coolant temperature sensor in it but it don’t fix the problem the truck runs fine and not overheating
Try connecting an OBD II reader capable of displaying live data, specifically engine coolant temperatures, observing cold engine temperature at ignition on time before starting and/or when idling. Good readers will update coolant temps with some requiring a screen refresh to reflect a different temperature. The reader displays coolant temp signals from the body conrol module. The bcm drives the instrument panel gauges. If a reader displays correct temps then the temperature gauge may be faulty or the electronics in the isntrument panel may be faulty.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 408
