跳转到主内容
加入维修社区 - 创建账户
2018年7月发布,15英寸 MacBook Pro,型号 A1990,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
Battery flex cable damage?
In replacing my fan, I believe I may have damaged the battery flex cable. I pulled the flex cable out without lifting the seat, and then was able to place back without issue. However, now the computer will only turn on with power cable. If it boots up and I remove the power cable, it immediately dies. With the flex cable reseated, It does recognize the battery, says it’s at 100% and hardware test shows no issues. The computer will also boot up without the flex cable in at all, but will shower an X in the battery, so at least part of the flex cable must be working. I ordered a new flex cable, but what is the likelihood that the logic board itself is damaged from pulling the cable out this way?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hey man this literally happened to me today when i replaced the screen how did the repair go after the new install?
完成的
添加一条评论
2个答案
最有帮助的答案
Here's the replacement cable MacBook Pro 15" Retina (Mid 2018-2019) Battery Daughter Board Cable
Replace the small flex cable that connects the battery daughter board to the logic board.图片
产品
$14.99
这个答案有帮助吗?
得分 1
添加一条评论
this is the exact same thing that happened to my macbook. Any fix?
这个答案有帮助吗?
得分 0
1条评论:
Replacing the cable of its damaged or if the socket is damaged you can replace them as well but you need good soldering skills, and the needed tools and part.
完成的
添加一条评论
添加你的答案
Josh Alinger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 28
总计 872
