跳转到主内容
Xbox Series X 是微软公司次时代4K游戏主机。2020年11月10日,Xbox Series X与其配套主机Xbox Series S一起发布。
42 个问题 查看全部
HDMI pin 18 trace ripped
Hey I'm having trouble locating where pin/pad 18 connects to the circuit board, I have a pulled pad on the board 3rd from the last on the right I believe to be pad 18. I can't seem to find any videos where someone has had a similar problem. I just can't find where to run the trace to complete the circuit.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
its will go to both sides of that pad then
这个答案有帮助吗?
得分 3
5条评论:
After further review I had told you the wrong pin it is actually number 17 the one to the direct left of the one pictured..I'm sorry for the mix up. If I'm thinking correctly it goes to the point above it but I still have no clue.
完成的
Thank you so much the amount of research I done turned up nothing but this is gold...I do have one other follow up question I'm sure ik the answer already but I just wanna make sure that pin 19 connects to the one right above it? And pin 14 goes down to that diode or fuse? I'm not entirely sure I'm learning as I go lol
完成的
@deathray01 yes thats right, you just follow the traces coming from the pad
完成的
I'm sorry I keep asking questions but pin 14 does it matter if its connected to the diode or does it need to touch it I seen on some videos where they soldered it directly to that diode but never showed if they actually fixed it and I was curious if that was the correct way I'm sure it is being that there were a few who done it.
完成的
@deathray01 they probably done that just to save them scraping the trace down to the copper so you can solder to the trace or diode it doesnt really matter
完成的
添加一条评论
添加你的答案
Evan Wise 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 35
总计 259
