跳转到主内容
Why is help displayed in the camera data display window?
After installing a fresh battery the word "help" is displayed in the data display window of the camera. There is no function when the shutter release is pressed, no film advance nothing is working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @cuzz
According to p.94 of the user manual, help indicates a winding motor problem.
The solution offered is to remove the battery and then re-install it.
What is the battery charge being shown by the 4 bar indicator in the data panel when you turn the camera on?
Just verifying that you installed a 2CR5 Lithium battery? Maybe check the voltage of the battery. It should be 6V. The shutter is locked when the battery has been depleted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 525
