installed ifixit replacement battery wont connect power adapter
Hi People,
so I did the full (took apart everything) repair as follwing:
2012年中期视网膜屏Macbook Pro 15''电池替换教程
everything back together, everything works fine.
Except the magSafe plug wont show any light. The replaced battery wont charge, but it is running my macbook... now at 76% ... till there will be no more juice left...
While I was putting the macbook back together, I had medium struggle getting the cable connection coming from the new battery into the mainboard. After 3rd attempt with more and more pressure i relaxed my mind and it worked out easy.
I think all other connections should be ok. Also rechecked everything.
One more thing... I got twited memory... maybe i didnt turn the macbook off before... i dont know somehow :D
Do you think i should just buy the used i/o board with the power in for magSafe to speed up my repair time?
Do you think i need a new battery? I mean its working really good!
I need my second brain back quickly...
Please Help ! :)
All the best from Germany,
Marcel
3条评论
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
由 Dan 完成的
Sorry for that...
由 Marcel 完成的
I see you say you checked everything, but are you sure you didn't crush any of the connector pins and that it is seated correctly? I apologize if you indeed did go back and do this. Usually the best place to start any troubleshooting is by beginning with possible physical issues first.
由 ryanhurtt827 完成的
