跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
Is there a maximum storage capacity?
My Mac Mini Late 2012 has a Fusion Drive (1 TB HDD and 128GB SSD) and it will not reinstall MacOS because the HDD SMART status is failing. Since the hard drive has to be replaced, I'm looking to upgrade it to an SSD and I'm wodering if there's a size capacity. Can I replace the HDD with a 2 TB SSD? If not, could I replace it with a 1 TB SSD?
Thank you in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
A 2TB SSD should work fine. The 2012 models do not have a reachable storage limit due to being UEFI.
这个答案有帮助吗?
得分 1
添加一条评论
You will want to remove the blade SSD within the Fusion Drive set.
I just upgraded my 2012 with a new 4TB SSD to hold my media and will likely add in a second.
Think about getting a new blade SSD 512 GB or 1 TB for your OS and apps. It will make your system sing!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tyler VZ 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 1,018
