跳转到主内容
First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
Where Can I Buy A Replacement Battery?
Hello,
I own a Apple iPad 1st Generation 64GB 3G/GPS or A1337 of which when I plug in and attempt to turn on boot-loops. When I attempt to put it into DFU mode and plug it into a PC or Mac it will either immediately turn off (the iPad only boot-loops when plugged in) or if I used a adapter that allowed it to be plugged into power and the Mac or PC at the same time, it would not show up on iTunes. I'm 95% sure that it is a battery problem meaning I need a replacement battery. I looked on the iFixIt Store and the oldest iPad they supply parts for (let alone battery replacements) is the iPad 2 and anywhere else I could find that supplied battery replacements for the iPad 1st gen were on sketchy websites or hosted by sketchy sellers on places like EBay and AliExpress (even Wish at one point)
If anyone can help by sending a link or showing me a place to find a replacement battery I would be really grateful.
Thank you,
-Jenson
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Your right about it being a battery issue!
Part: iPad Battery
Guide: iPad 3G Battery Replacement
Replace a 6600 mAh battery compatible with iPad 1st Gen A1219 and A1337 models Wi-Fi and 3G. Battery model #A1315. 3.7 Volts (V). Part #616-0448.图片
产品
iPad Battery
$38.99
这个答案有帮助吗?
得分 0
添加一条评论
If you’re in the uk look for seller like Replace Base or repair outlet. Trusted sellers I use all the time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jenson Cutting 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 137
