跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
132 个问题 查看全部
iPad 6 battery drain while standby
I’ve received and iPad 6 to repair. Turns out not only the glass was broken but the battery was dead and the LCD is cracked.
I’ve replaced the glass and the battery. The iPad turns on and works great. Except for the cracked LCD which I still need to replace.
Before investing in a new LCD I noticed that the battery would drain quite fast.
I’m losing about 2% an hour while standby. Playing a YouTube video will drain the battery from 100% to 0% in about 3 hours.
Notes and things I’ve tried:
  • Restore the iPad (I’ve not yet done a DFU restore)
  • I’m not signed in to iCloud, iPad is factory reset. There are no apps running, no Find my process.
  • Charge to 100%, run it down to 0, charge to 100% and leave it for 4 hours.
  • When at 100% and connected to Coconut Battery it says 96% charged. When doing a force restart (home + power) it reboots and jumps from 100% to 96% and goes back to charging for a couple of minutes. Doing this a couple of times will end up with 98% in Coconut Battery and 100% on the iPad.
  • Update to iOS 15.6.1
  • The iPad get ‘warm’ on the rear when in use. Right around the motherboard battery connector is my guess.
Could the battery be bad or could there be something else wrong with this iPad?
Could the cracked LCD cause the drain?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The battery would be the quickest and easiest part to check by replacing. If that does not resolve, the iPad may have a bad Tristar IC or a short on the board which will require micro soldering to repair. The cracked LCD should not be the cause of the issue. If the device has a bend in the frame this is most likely the cause of the board issue if one is present.
这个答案有帮助吗?
得分 0
3条评论:
Thanks for the response Robert. No bend in the frame as far as I can tell. I don’t have the tools to check the Tristar IC. Wouldn’t issues with the Tristar IC be more ‘visible’? Like unable to charge etc? I could buy another battery but the costs are adding up sadly. Not sure if that’s worth it.
完成的
An update: I've bought a new battery to make sure that's not the problem. Turns out it wasn't the battery. This new battery also drains just as fast. So sadly it must be something else that I'm probably not be able to fix.
完成的
Hi Rick, sorry just now seeing these comments. If the battery did not resolve the issue, there is most likely damage on the logic board causing the problem.
完成的
添加一条评论
添加你的答案
Rick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 52
