跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Boot Loop On Plug-in, Button Fixes Do Not Work
My phone will instantly boot-loop on connection to power, white apple logo.
Will restart every 10 seconds.
Power + Home button holds do not work
Volume Up/Down buttons do not work.
Tried all buttons, the 'pressing onscreen trick' etc.
Nothing seems to work.
Of course, there is no connection visible on computer.
There is no response to any button holds whatsoever, the apple logo still loops every ten seconds.
Any body got a fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi
When its not turning on and it’s boot looping that usually means time for a new battery
Here’s a guide for replacing it!
iPhone SE 电池更换
Here’s a USA link for a Battery
iPhone SE (1st Gen) Battery
Here’s a EU link for a battery
https://eustore.ifixit.com/products/ipho...
Here’s a UK link for a battery
https://store.ifixit.co.uk/products/ipho...
If you are outside the stores I have listed please let me know and I can get you the correct link
Hopefully this helps
Any questions please ask
Replace a 1624 mAh battery compatible with a 1st generation iPhone SE. 3.82 Volts (V), 6.21 Watt Hours (Wh). This replacement does not require soldering.图片
产品
$29.99
这个答案有帮助吗?
得分 1
2条评论:
It could be from water damage too, but most likely a battery issue for sure.
完成的
@cooltool
You are correct about the water damage,if they find any they can remove it while they are replacing it:-)
完成的
添加一条评论
添加你的答案
Royal Toad Club 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 15
总计 89
