跳转到主内容
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
49 个问题 查看全部
Pro 5 1796 not detecting new battery.
Hello all, I recently replaced the battery in my Surface Pro 5 1796, and upon powering it back on, Windows shows no battery present in the tablet. There is no battery icon in the taskbar, no battery settings in the Settings app, and upon checking device manager, it says that the Surface Battery is not installed in the computer.
Despite this, the battery is still sending power out to the system. I can unplug and use the device just fine, but when the battery dies, it immediately shuts off. No low battery warning, sleep state, or low battery icon from the UEFI when you try to power it up. Just a black screen.
This tells me that the battery is seated correctly in its spot, but something within the software is messing it up. I've tried reinstalling drivers, doing windows update, and performing a Surface Diagnostics Test, but to no avail. I have yet to try a full re installation of Windows.
If someone has any tips or solutions to this, please let me know. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Update: Solved! I ended up opening the device back up and finding the battery connector misaligned with the pins on the back of the motherboard. After adjusting the battery and reinstalling the ACPI Compliant Battery thing in Device Manager, the battery shows up!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
x1nni 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 31
总计 439
