跳转到主内容
加入维修社区 - 创建账户
这是由索尼电脑娱乐(现已重组为索尼互动娱乐)生产的游戏主机。PlayStation 4 Slim(CUH-2000系列)是比初版PS4更薄的替代型号,于2016年9月7日正式对外公布。
controller help please please
so my ps4 is fine works fine turns on all that . but my controller won't pair anymore . if it's plugged in it charges , i can even use it on the safe mode screen but once it's on the regular start up screen where it says press ps button it doesn't work anymore the light blinks white && it goes back to juss charging it . i juss wanna play my game
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Try this
在故障或损坏后修复PS4蓝牙天线
这个答案有帮助吗?
得分 1
添加一条评论
Hi, there are a couple of things you could try.
  1. Have you tried a different cable?
  2. Reset PS4 controller
1) Turn off your PlayStation 4.
2) Locate the reset button, and it’s on the back of your controller near the L2 shoulder button.
3) Use a small and unfolded paper-clip or something like that to push the button and hold it down for a few seconds, and then release it.
4) After resetting the controller, re-pair the controller with the PS4 by connecting the USB cable correctly, and turn the PS4 on.
5) Press the PS button to log in to the PS4.
Your controller should connect to your PC4 console and start to work.
  1. Try another controller
If you have checked the USB cable and find no problem with the cable, you can try another PS4 controller (if possible) to see if it’s due to the controller hardware problem.
1) Use another PS4 controller to turn on your PS4.
2) Shut down your PS4 completely.
3) Unplug your PS4 cable from your PS4, and wait for 3 minutes.
4) Re-plug your PS4 cable to your PS4 correctly.
5) Plug another connector to your PS4 controller that occurs the problem.
6) Turn on your PS4 now and see if it works properly
If one of these 3 doesn't fix it, it should at least try and help you narrow down more specifically where the issue is
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kenya colbert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 182
