跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
I can't hear nothing when I call
Hello,
I have this problem, when I call I can't listen nothing, I have change the plastic support with the new flex but the problem is not solved
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Can you play music through your speakers? Can you hear anything with headphones plugged in? Do any apps put out sound?
完成的
Speakers are okay and i hear apps sound through the speaker but when i put iphone near my hear during call i can't hear nothing
完成的
Do you hear anything when in a call with SPEAKER selected as per pic in answer below? NB added extra info to my answer.
完成的
添加一条评论
2个答案
最有帮助的答案
During a call can you select speaker as the output? If this works then the likely problem is the Earpiece Speaker is faulty.
EDIT - There are 2 audio devices - speaker at bottom (part of the dock assembly) of iPhone that will play apps sounds and the ear speaker that is used for calls when NOT on speaker (as per pic above)
The Speaker is part of the Front Panel Assy
This YouTube Video may also be worth a look if you want to try replacing just the speaker.
It could also be the cable assembly is not connecting to the speaker properly (corrosion on contacts) or is faulty.
NB Best I can determine, same speaker suits 3G and 3GS.
Replace the 30-pin docking port assembly in an iPhone 3GS and fix problems connecting to USB devices, charging problems, loudspeaker audio, and microphone functions.图片
产品
iPhone 3GS Dock Connector
$19.99
这个答案有帮助吗?
得分 1
2条评论:
During the call I can select the bottom speaker and its works, if I plug the headphones I can hear everything normally, I have change all the front panel yet so this is new, I think the problem si the connector of the logic board where I put the ear speaker's flex! is it possible??
完成的
I guess it could be the connector, or the logic board. I assume you have tried to reseat it again. It is also possible the front panel you got is faulty.
完成的
添加一条评论
My phone rings but when I answer it I can't hear anything but when I put it on speaker it works fine
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nazareno Distefano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 9,473
