跳转到主内容
The Beats Solo Pro is for the listener who's always on the move. Noise cancelling is surprisingly effective for a pair of on-ear headphones. Although the sound signature remains bass-heavy, as is emblematic of Beats, it rarely overpowers vocal reproduction.
11 个问题 查看全部
Why is my solo pro just blinking white light non stop for hours?
It’s just blinking white light for over 24 hours now and it doesn’t connect or turn off even when I tried all the resetting techniques online it’s pretty much useless and sitting there now
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Hi
This issue is usualy caused by the logic board or the battery
Here’s what to try!
Try leaving them so that the battery goes flat and then try charging them up
You could also try disconnecting the battery by following this guide(this usually works in most cases)https://m.youtube.com/watch?v=SBeHaqnw45...
If the above doesn’t work I would try replacing the battery which uses the same link above
If all these don’t work please let me know
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 2
添加一条评论
Hello. Tried all your steps.
Finally changed the battery. And it start again blinking white do you know what I can do more
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Albert Eintein 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 79
过去 30 天: 425
总计 8,258
