whirlpool MOD#ED5FVGWXS06 freezer and fridge are not cooling
I have whirlpool MOD#ED5FVGWXS06 freezer and fridge are not cooling I need help pls
Hi,
Can you hear if the compressor motor is running?
If not it may be a faulty capacitor (supplier example only to show location of part and possible cost). If it is determined that it is the problem search online for WPW10662129 to find other suppliers that may suit you better.
If the compressor is running it may be a thermostat problem.
Worst case scenario is a problem with the sealed system e.g. faulty compressor or a lack of refrigerant due to a leak.
If it is a sealed system problem then you may need to get a licensed repairer to check it out due to the environmental regulations regarding the handling of refrigerant gases.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 26
