跳转到主内容
A sports sedan manufactured in 2003-2004 by Infinity
5 个问题 查看全部
turn my car off the tail lights stay on.
I have a 2003 Infinity G35. My starter went out so we replaced it and the battery. Now when I turn my car off the tail lights stay on. I'm a female so I'm not very mechanically inclined and I'm freaking out. Could the computer be going out in my car?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You have to first determine weather it’s your parking lights or your brake lights, brake lights are much brighter than your parking (or tail) lights. When they’re stuck on go to front of car, look to see if the front or side lights are on as well. If they are then you have a stuck parking light issue if not and the rear red lights are only then you have a brake light issue. Either way first check that you have all the connections right on your new battery and starter and that no other wires were disturbed. If it’s ok and brake lights only then you can refine your question to brake lights stuck on. Which would probably be a brake light switch.
这个答案有帮助吗?
得分 1
1条评论:
It is the brake lights, no front lights stay on. I've googled and I'm gonna attempt to fix it myself. I found the brake light switch, but am clueless as to where the right fuse is
完成的
添加一条评论
最有帮助的答案
Hi,
Just verifying that it is the tail lights that stay on and that it is not the brake lights that stay on? Do the lights glow more brightly when you depress the brake pedal? If not it is the brake lights.
If it is the brake lights, check that the brake light switch is OK .
Here's a link that may help
这个答案有帮助吗?
得分 2
1条评论:
I looked at it more and I think it's the brake lights. Will having Orielys hook it up to the computer give me answers?
完成的
添加一条评论
添加你的答案
Angela Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 36
过去 30 天: 144
总计 831
