跳转到主内容
ASUS laptop model Q302L with a 360 degree rotating touchscreen display.
11 个问题 查看全部
Motherboard exchange Core 13-4030U with Core i7-4770S
can I replace the motherboard of ASUS Q302L Core 13-4030U with the motherboard of TP300L Core i7-4770S also called I7-4th Gen?
Update (08/23/2022)
my old motherboard has 6GB ram and the new one has 4 GB ram is it not going to be any issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes, it should work fine because TP300L Core i7-4770S supported both types of RAM memory like DDR3-1333/1600, and DDR3L-1333/1600. So, the old motherboard RAM should be supported by this motherboard. Finally, you have to check by replacing.
这个答案有帮助吗?
得分 1
4条评论:
完成的
Usually, version like DDR3 or DDR4 and FSB causes the issue. The old motherboard and new both use DDR3. so there is no issue with RAM type. The new motherboard supports both types of FSB. So, there should also not be any issue with FSB.
If you are talking about RAM capacity it could create an issue. The upper version of windows 7 like 8, 10, or 11 needed at least 8 GB of RAM to work well. Below that it will starts freezing while using two or three software at a time. It will work with 4 Gb Ram but you will not get good performance mostly using the browser or internet.
完成的
can I just take out and put 8 GB ram?
can i do that?
完成的
You can do that but my opinion is that uses multiple RAM in place of a single big Ram. The reason is that a single 8 Gb Ram only gives you a specific clock speed as well as cache memory. While using 2*4 or 4*2 Ram gives you extra clock speed with a cache memory of each Ram.
完成的
添加一条评论
添加你的答案
Framan Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 71
