跳转到主内容
加入维修社区 - 创建账户
This Audi A6 model received a facelift in 2001 for both sedan and Avant versions. The revised A6 sedan featured a new grille design and different headlights, while also being fitted with a wide range of petrol and diesel engine configurations. Most of these powerplants received a boost in power outputs.
Why won’t my radio turn even after I buy a new radio?
My radio won’t turn on before it went out completely ot would turn on and off at any time while the car was on. I bought a new radio it still has not worked. How do I fix this??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
You'll need to verify it is getting power. Check the fuse for the radio. Also check that it is getting power to turn on when ignition is turned on. I want to say yellow wire? Not positive. Check your wiring diagram for the new unit to make sure where power should be coming in at.
完成的
添加一条评论
1个答案
Ensure the proper fuse(s) are in place and working properly
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Juan hernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 415
