Where is the transmission solenoid located
Where is the transmission solenoid located in my 09 Dodge Journey R/T - V6 - 3.5L?
V6 - 3.5L 3497cc 215ci GAS MFI vin V - 4 valve SOHC
Update (08/22/2022)
Yea ... not on my car
Hi @tonez12
If it is the 6 speed AT then here's the 62TE transmission service section from the repair manual for your model.
It shows how to ID the transmission so that you can check if it is the correct one.
The solenoid (if it is the correct one) is mentioned on p.212-214
Hopefully a start
这个答案有帮助吗?
Thanks so much
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 72
总计 2,461
2条评论
Hi @tonez12,
Does your model vehicle have the 6 speed auto transmission?
由 jayeff 完成的
6 speed front wheel drive axle I believe ... I'm learning as I go so please bare with me. My journey is a AWD so I'm not sure if that makes a difference.
由 Rachael Abeyta 完成的
