DR Pulse (battery powered) trimmer/mower switch problem
The motor engages then shuts off after seconds, or minutes, if I'm lucky, of mowing. Occasionally it will run for an entire battery charge (less and less often tho.) The battery is fine, it charges fine. The problem seems to be in the switch. Once in a while, after it quits, it will restart itself without pressing the start button. (It's a long expensive trip to get this machine in to a shop.) I keep trying to get some mowing done, but probably just wearing out the starter switch.
Thanks for any suggestions - Billy
Hi @maplebilly,
What is the model number of the trimmer/mower?
由 jayeff 完成的
You'll need some kind of wiring diagram. The self-restart infers an intermittent safety interlock switch. Temporarily bypass any you find.
由 Kevin Sargent 完成的
Thanks jayeff and KS. It's a DR LiPro 62volt, model# T4X3062XEN, built in 2019.
Hmm, wiring diagram, good idea.
由 maple billy 完成的
