跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
2013 MBA with Boot Issues
I offered to help a friend with a 2013 MacBook Air that was having issues.  His only complaint was that the keyboard had been non-responsive, so the unit got shelved and forgotten about.  His son wanted to use it again, so they asked if I could help.  I took it home, plugged in the charger (it lit up orange), after a few minutes I booted it up with an external keyboard attached via USB.  Unit worked fine, aside from the keyboard not working at all.  Seemed like it was registering the “comma” button being constantly pressed, making a low beeping sound.  When I pressed the comma button, the sound would stop.  I could see the same results when opening Notes.  While confirming that the battery was charging, the info panel read that the battery could be ready for replacement (or something to that effect, was over a week ago).
Figuring it would need a keyboard replacement, I shut the unit down and let it charge up.  This is when things got weird.  Charging light was green, but when I tried to boot it up, the unit would not respond.  Through trial and error, found that if I pressed and held the Power button, it would boot up with the fan blowing full speed.  After a few attempts, the light went out on the charger and hasn’t been on since.
I’d like to fix this unit for him and can buy parts, but I cannot determine if the logic board is bad, IO board failing, or is a bad keyboard causing all this?  Replacing all those parts will likely surpass the value of the laptop.  Logic board is the most expensive, but if that can be determined to be the only issue, would be worth doing.
Is there any method to further troubleshoot to narrow down which piece of hardware could be causing the issue?
Symptoms:
  • Laptop keyboard does not work, but any keyboard plugged into USB works. (initial complaint)
  • Trackpad works but any click works only like a right-click (holding Control while pressing on trackpad)
  • Sound works fine
  • Camera works fine
  • No light on charger when plugged in
  • Will boot only by holding down Power button while plugged in.  Must continue to hold down power button through boot process until home screen pops up or the unit will shut down – usually not immediately, but before it reaches home screen.
  • While running, fans going full speed
  • Turns off as soon as unplugged
  • Battery not recognized (coconut battery picture below)
Findings (using Apple USB Keyboard – A1048:
  • Can boot into Safe Mode (if long press power button while holding shift key)
  • Can boot into Recovery mode (long press on power button while holding Command-R)
  • When trying to reset NVRAM, unit starts up, no chime but fans full speed, then shuts down.  Only way to boot up again is disconnect power connector for a brief period of time.
  • Attempted SMC reset with USB keyboard.  Unsure if it did anything as it still has same boot behavior.
  • Booting into Diagnostic mode shows three codes:
    • PPT001: Battery not detected
    • PFM001: Issue with SMC
    • NDC001: Issue with camera
Things I have done:
  • Removed and cleaned logic board & IO board – just brushed off dust, inspected for any clear signs of damage (none seen)
  • Booted up with the ribbon cable between IO board and logic board disconnected – no change in behavior
  • Booted with battery disconnected – no change in behavior
Coconut Battery Picture
Images of Battery
Logic Board Pictures
Trackpad Pictures
Keyboard - definitely signs of spillage
Coconut - 8/25
I/O Board
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论:
Have you tested the PS output? Is it correct voltage and amperage?
How about the battery? Correct voltage and amperage?
My first suspicion is bad battery followed closely with power switch.
完成的
Can you post that CoconutBattery screenshot so we can see things 在已经存在的问题里加入图片
完成的
@danj Done! Pictured added.
完成的
@kidsinaustin - mmm ... Looks like the USB port has corrosion! The MagSafe not bad a little cleaning is all it needs. But that USB port... That could be messing you up. Best to try a new one MacBook Air 13" (Mid 2013-2017) I/O Board
完成的
添加一条评论
1个答案
Yep! You've got a bad battery, basically the micro controller within the battery has failed. You'll need to contact the seller of the battery to get a replacement.
这个答案有帮助吗?
得分 0
18条评论:
Thanks Dan! This is the original battery. Would its failure cause all these issues?
完成的
@kidsinaustin - Take a picture of the battery labels, I don't think it's the original. 在已经存在的问题里加入图片
For a frame of reference, I'm banging on a 2012 which is now on its sixth battery as they only have so much life. So it's got to be on its second battery by now at least unless its been sitting in a closet for a few years.
The fact the keyboard & trackpad are having troubles is telling me the batteries cells are swollen pressing up against the uppercase messing them up. So you need a new battery in any case MacBook Air 13" (Late 2010-2017) Battery so less the system got wet you should be able to get it going with just the battery 2013中期 MacBook Air 13" 电池更换
完成的
@danj - Sure enough, the battery date is 2013! My friend got his value out of that purchase! I noticed when flipping the battery over the residue, feels a little sticky. Leaking fluid?
完成的
@kidsinaustin - Not sure if this is for the battery cells or some other source. Does the cavity have signs of leakage within the keyboard and tackpad areas or on they cables.
Time to pull the logic board to inspect it. Check the other side for liquid spill damage. MacBook Air 13" Mid 2013 Logic Board Replacement Post some pics if you see anything or have a question.
完成的
@danj Logic board removed and pictures of front and rear. Are there any "moisture detector" stickers or markings? I didn't see any, but not sure what to look for on an Apple board.
Before pulling the board, I removed the battery and booted up the device. It first booted on a quick press of the power button, but after a few cycles reverted to a continuous long press to boot up.
Without battery, keyboard still did not function. A couple of boots I had the left click on the touch pad, but others were the same with only the right click.
完成的
显示更多的13条评论
添加一条评论
添加你的答案
3kidsinAustin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 256
