Cannot Turn on MacBook Pro
I have the same issue with my 2008 macbook pro a1260. I've replaced the adapter - no luck. shorting the power jumpers on the logic board doesn't power it up. Tested the voltage on the adapter = good. tested the volts where the magsafe port connects to the i/o board (the pins) = ok. but it won't do a thing. I'd hate to replace the i/o board when it's the logic board, and vise versa. Any better way to test each board?
What color is the LED on the magsafe? Is the new magsafe 60w or 85w? What voltages are you reading?
由 ABCellars 完成的
