跳转到主内容
主板和 CPU 维修指南。
Why is my display going black after installing display driver?
I have recently bought a PC with Athlon 3000G processor, Gigabyte MB A320M H (AMD AM4 A320/REV.1.1), Crucial 8GB 2666 Mhz, BLUEFEATHER SSD 256 GB. I installed Windows 10 64 Bit Pro. I installed all drivers from MB. When i install GC driver, the screen goes black and nothing comes on. I restarted the system and the screen stays black after initial BIOS load. Please advice. I have tried 10 times till now.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
What GPU card is installed as you never mentioned it, you just said GC (game cube??) driver?
The CPU has integrated graphics so try using the onboard graphics and check if the display is OK. Either remove the GPU card or set the primary display setting in BIOS > Peripherals > Initial Display Output to IGD video. Connect the monitor to the motherboard video connector, not the GPU card.
Alternatively try starting in safe mode with networking and check if there is a display.
If there is then there's a driver problem as only generic Windows drivers are loaded in safe mode.
这个答案有帮助吗?
得分 1
5条评论:
I dont have a GPU Card. I am using the AMD APU Graphics. I have installed Windows 11 and still the same issue. I have given it to the service center as per their support advice. Let me update later on resolution.
完成的
@BALAJI VEERARAGHAVAN
just confirming that you tried the latest Win 11 Athlon 3000G amd drivers?
Did it work in safe mode, you didn't say?
完成的
Yes. Win 11 as well. It didnt work. Its going to be serviced/checked on Monday by Gigabyte Technician. I didnt try it in Safe Mode. Even if it works in SM, i still need to insall some Apu driver to get better resolution.
完成的
Gigabyte Service guy tested with my MB and his components and the display is coming without any issue. No need to take the processor to AMD to check it out.
完成的
MB doesnt have any issues. Additional GC is working perfectly. We have narrowed downt the issue to Processor. Have given to service center.
完成的
添加一条评论
添加你的答案
BALAJI VEERARAGHAVAN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 158
