跳转到主内容
捷威所制造的台式机的支持界面。 现在捷威被宏碁的子公司,现在捷威所有新的产品都是宏碁公司旗下的产品。
How do I remove the case off my gateway dx4831-07
i removed some screws on the back but i can't pull or slide the case off
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
i got it open but now the stupid power supply unit fell inside and i cant get it out
完成的
添加一条评论
1个答案
已选择的解决方案
Looking at the back of the case. There are 2 screws along the left side of it. Just remove those 2 screws, and that side part of the case will slide towards the back.
The Power Supply appears to be held in by 4 screws, and has various tie down points within the case for the cables.
Ensure the machine is powered off, and disconnect the red/yellow/back cables leading from your power supply to the motherboard. These generally have notch style locks that you can easily undo by applying a bit of pressure, and pulling straight out.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
anthony 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 514
