跳转到主内容
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
176 个问题 查看全部
Do I need an iMac memory module thermal pad?
Well the iMac has been taken apart.
I have found that the previous owner did an ifixit upgrade to 32gb as the modules have the ifixit logo. However they don’t have the thermal pad.
I have 16 gb of new crucial Mac certified ram, which I am about to install but no thermal pad. I wonder is it essential?
if so what size or thickness or type do I need?
I also noticed what looks like corrosion on one of the Bluetooth antennas. Should I be worried? Do I have to replace?
I also found this (a square black sticker) stuck at a random angle on the back of the display. It’s about the right size and shape to cover the cpu, but perhaps it’s supposed to be stuck on the display to protect it from cpu heat?
Any help much appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@colmstiofan That black sticker looks similar to what I've seen on iFixIt/3rd party iMac display adhesives. I would not worry about it unless it impedes airflow or something.
I don't spot any corrosion from your photos, like @danj said , the color is a bit off, but that is normal from heat after some time, depending the conditions the machine was kept in.
Thermal pads on RAM is never required, and is really only common on laptops and small form factor machines, I would not worry about it on your iMac.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Generally you don't need any thermal pads on the RAM. While they do get warm you're not going to push them to failure.
I would get a good thermal monitoring app like TG Pro it will allow you to monitor you systems temps and allow you to boost the fan when you are running something that pushes things.
The frame looks a tinge off in its color, but I don't think its corrosion. I would leave it be,
As far as the odd sticker I would leave it be as well. The few 21.5" systems I've done I don't remember seeing it so it just could be a fluke as it really doesn't offer any protection from heat, it just offers some insulation from something shorting.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Colm Ó Canainn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 183
