跳转到主内容
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
188 个问题 查看全部
Apple Watch Series 3 cellular battery in Apple Watch Series 3 gps?
I have a Apple Watch Series 3 gps and cellular the cellular has a broken screen but the battery works and the gps has a dead battery. I’m just wondering if I could use the battery from the cellular version to see if it would work before ordering a new one.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hey you're not Linus! LinusTechTips. How about changing to fictional person or icon that would be nice!
完成的
添加一条评论
2个答案
已选择的解决方案
Well... Maybe! You didn't tell us if the two watches are the same size or different.
If you have the same size then you can test the watch but you can't seal it up as the batteries are not the same size.
这个答案有帮助吗?
得分 1
1条评论:
Sorry I forgot, yes they are the same size
完成的
添加一条评论
Hi Luis,
Kind of looks like you're out of luck; you don't mention if you have the 38 or 42 mm model, but in both cases the cellular vs. GPS versions take batteries with different part numbers and slightly different mAh ratings, so outside of someone who can definitively state that they've successfully swapped them, I would assume they're not compatible.
Apple Watch Series 3 Batteries
Generally a manufacturer will reuse parts wherever possible to save themselves manufacturing and inventory costs, so having the two models take different part numbers is a good indication they're not interchangeable.
EDIT: Ah, just saw @danj's response; we must have been typing at the same time. He's right that the connectors are probably compatible so you could use the good battery to test the other watch, but ultimately you'll have to buy the right one in order to fit it in.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Luis Schuster 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 42
