跳转到主内容
ASUS laptop model Q302L with a 360 degree rotating touchscreen display.
11 个问题 查看全部
wifi card for asus
how to upgrade wifi card
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Framan Ali,
Replacing the WiFi card on your laptop is relatively easy. Unfortunately there isn't a guide specifically for that here on iFixit, but all of the instructions you need are available within the motherboard replacement guide.
ASUS Q302L Motherboard Replacement - iFixit Repair Guide
Obviously you don't need to remove the entire motherboard to accomplish this; as a matter of fact you can skip most of the steps. Just follow the steps listed below in order and you won't have any problems.
Step 1 Back Case
Step 2
Step 3
Step 5
Step 10 Motherboard
Final step is to just remove the screw circled in red below.
Lift the WiFi board slightly on the edge opposite the connector then slide it straight out to remove it.
Now that you know how to do it, I'm afraid the question of what you can replace it with still remains. Unfortunately I don't have an answer to that; hopefully more knowledgeable users on this site can help.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Framan Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 111
