跳转到主内容
iMac G5 Won't Start
My iMac G5 seemed to be running good. I then unplugged it from power for a few days. When I connected it back to power and tried to turn it back on the cooling fan immediately went to full speed, there were three loud beeps, the white front power light flashes 3 times pauses and then follows this sequence again. Also the screen remains dark. It will stay in this state of limbo with the cooling fan racing until I hold the power button in long enough for it to turn off. Does anyone have an idea of what the problem could be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
This is a RAM error. Try first reseating the RAM. Next we need to test both the RAM and the slots. Use just one stick and try it in both slots, see if you find a bad stick or bad slot. Remember to touch the case while it is plugged in before working on RAM to discharge any ESD before doing this work.
这个答案有帮助吗?
得分 3
1条评论:
Thank you for your help. You were spot on. I has a bad stick of RAM.
完成的
添加一条评论
添加你的答案
Mark Gregory 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,125
