跳转到主内容
Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
91 个问题 查看全部
Replaced rear glass, damaged flashlight and now front camera is black?
Hi All,
A few days ago I replaced the rear glass on my iphone 12 - it went relatively smoothly, but I managed to accidentally break the flashlight off during the replacement - the rear camera still works fine (without the light / flash of course) - but the front camera doesn't work at all anymore - is this because of the flash ? - If I replace the flashlight ribbon, is that likely to fix the front camera problem?
I don't know if it's something different - but face ID still works fine! - does that use the front camera or is that a different component again?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Based on what I could find, it is unlikely this is due to the flash. The flash enable is often related to the camera’s presence, so it generally does not work if the rear camera is non working. But in my experience, the opposite isn’t true. And front facing camera is rarely in the mix, unless the issue is on the board side.
If you haven’t reseated any of the internal cable connections, that would be my first step. Next I would check the front facing camera cable for signs of damage.
Did you remove any of the internal components before replacing the back glass? What method did you you to get the existing glass out? Is Face ID working even though the camera is not? Sorry for all the questions, this issue just piqued my interest, hahaha.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the reply!
The glass replacement was just peeling the existing glass off (with a heat gun and the usual tools to pick/lift pieces off). Everything seemed unharmed except for the flash, which I accidentally nudged as I was trying to get between the 2 camera lenses!
No dismantling was done - the screen hasn’t been off so I’m not sure how I’ve killed the front camera!
Face ID works fine - in fact, I’ve reset the phone today in the hope that might fix it - and in doing that it reset Face ID - I’ve now setup Face ID from scratch, you can’t see yourself when you set it up, but it works and recognises movements etc! I guess that must be a separate camera.
完成的
Yes, Face ID functionality is an amalgamation of a few different parts. And the front facing camera is actually not really necessary. Loathe as I am to say it. I think you’re going to have to actually get into the phone to diagnose this one. The 12 series is a bit of a bugger to get into. But if the issue is just the front face camera, rather than other components of Face ID, it should be replaceable on its own.
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 29
过去 30 天: 109
总计 449
