Keyboard backlight not working
Hi. all
i had to detach my MacBook pro 15 " 2018 (A1990) screen because it was broken.
The keyboard backlight dies not. work anymore.
Did I mess something. up or the backlight cable is connected. to the screen?
If your screen is no longer attached, the reason your keyboard backlight does not work anymore is likely because your computer can no longer communicate with the ambient light sensor. The ambient light sensor is part of the system which sets the auto brightness for both your display and the keyboard backlight. Without this data the device just removes this functionality. You may still be able to adjust the backlight settings manually using the Touch Bar. But I have see occasions where it won’t work at all in this case.
这个答案有帮助吗?
Well Said! :-)
Yeh , That is what I figured out after some googling.
but the whole thing is working perfectly except for the backlight and the chime at startup ( which is weird ). but. I am ok with that. itis a small tradeoff :D
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 28
总计 981
4条评论
Here is the photo[image|2712864][image|2712867]
由 wael 完成的
@wael - Can you show the ribbon cable for the backlight?
由 Ben Capehart 完成的
I just need to know if the keyboard backlight is related to the screen being attached? Meaning that when I remove the screen from the lapto like in the above photo. Will the keyboard backlight work?@beanman56
由 wael 完成的
@wael - It doesn't seem like that would be the cause
由 Ben Capehart 完成的
