跳转到主内容
Apple's fifth-generation smartwatch, with optional cellular connectivity, released September 20, 2019.
20 个问题 查看全部
Apple watch series 5. What are these cables on the display?
Can anyone identify the 2 pictured cables?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
They are the EMI shield connections to the watch case to prevent signals to/from the display and the S5 SIP unit.
Here's a better view from the other side
Here you can see the three cables being shielded.
这个答案有帮助吗?
得分 1
17条评论:
Both of those cables pulled loose / tore away from the display. I've not been able to find replacement cables and it doesn't appear they come with the replacement display cable. Any idea on where to find them or can I do without?
完成的
@bad_karma - Yes, they are easy to tear!
I cheat! I use conductive tape patching the exposed foil side. That way the emissions have a way the case.
完成的
Do you have a picture showing what you have described above?
完成的
@bad_karma - Here's the needed tape Conductive Electrical Tape All I do is cut a piece place it across the copper surface and lightly tack it down with solder.
完成的
@danj not quite sure I follow you. My cables tore from the pad that is secured to the case and also from the back of the display. Am I simply using the conductive tape in lieu of the cable? If so, how do you fasten it to the case?
完成的
显示更多的12条评论
添加一条评论
@danj: You can see in this photo that the small cables are disrupted on both sides. Are you suggesting that I solder one end of the tape to what's left of the cable at the case end and the other to the shield itself?
这个答案有帮助吗?
得分 1
1条评论:
Re-read what I wrote. I clearly stated one will need to apply a thin strip of conductive tape to patch the break. Soldering is only an option when the tear doesn’t offer enough surface. I also stated one strap often is enough.
完成的
添加一条评论
添加你的答案
bad_karma 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 390
