跳转到主内容
加入维修社区 - 创建账户
Apple 在 2020 年十月更新了 iPad Air 平板电脑,其采用 A14 Boinic 处理器,10.9英寸屏幕,全新外观设计,以及内置在按键中的触控ID。
vertical strip of screen not responsive after repair - original screen
I have seen the answers to this include, probably repaired with a bad digitizer, try a new one, but this is the original screen that had no problems. Is it possible for the adapter to be seated incorrectly and a middle vertical not work? Seems odd. Any thoughts before I take it apart again appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi
This seems very strange but there is a verity of things it could be
1)it could be a bad connection due to it not being seated properly
2) it could be damage to the connector however if you look at both connectors (cable and board ) it should be fairly obvious if something is bent out or deformed
3) it could be some invisible dirt that our human eyes can see that needs cleaned off with a cotton bud and some isopropyl alcohol
If you try what I have mentioned and still have no luck please let me know and we can look into it further
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
If the issue occurred after the display was removed, something must have happened in the course of the repair. If it is only one stripe of the display, it's possible that one of the pins on the connector is not making a good connection, perhaps because it is bent, not seated properly, or there is something in the connector preventing it from making a solid connection.
It could also be that there is some minor damage to the cable responsible for touch function, or the digitizer itself.
Whatever the reason, it is certainly worth opening the iPad up again and having a look. The digitizer connector is the middle connector of the three that come off the display, the long one. Make sure the accompanying cable is free of damage.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
BGS 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 32
总计 659
