跳转到主内容
Repair guides and support for your Toshiba TV.
193 个问题 查看全部
Screen turned grey any help
There was a black line going through the screen and then the screen was being cleaned and when it got turned back on the whole screen had turned grey and no picture is visible any way it can be fixed without it being thrown out :/
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @kal06,
Too much pressure must have been applied at some time when cleaning the screen (or somehow it was hit with something) and it has cracked. - see image below
The screen cannot be repaired, it has to be replaced.
The difficulty with this is in finding a replacement screen.
Disconnect the power to the TV and remove the back cover and try to locate the make and model number of the screen on the back of the screen and use that information to try and find one. If you do find one, don't be surprised that it costs nearly half as much as a new TV.
An option to consider is to advertise the TV as Toshiba (insert model number), cracked screen, good for parts to try and recoup some of the cost towards a new TV. Working TV boards are always in demand.
(click on image to enlarge)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kaleese jenkins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 306
