跳转到主内容
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
154 个问题 查看全部
How do I replace the instrument cluster lights.
I have been trying to replace my instrument cluster lights. I have watched many videos and looked all over trying to find out how for my specific vehicle. I can remove the cluster but then the circuit board has one light bulb on it that indicates the head lights. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi,
What is the specific Altima model and year of your vehicle?
Have you checked for small smd LEDs on the board?
完成的
添加一条评论
2个答案
normally the bulbs are very small and they are socketed.
If you have the cluster out, you should be able to drill down, removing the PCBs till you can see and remove/replace the bulbs.
这个答案有帮助吗?
得分 0
添加一条评论
I just ran into this issue as well I tore the entire unit apart on my 2006 nissan altima s with 2.5l to find out the lights are non serviceable led bulbs soldered to the cluster board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Lemon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 424
