跳转到主内容
Repair guides and support for your Samsung TV.
2610 个问题 查看全部
Sound and backlight but no picture
Samsung un60hu8550f
2 yrs ago was getting that fan error and replaced the mainboard. This week the dark screen with sound. Backlight working. Initially got it to with for a minute with a dark red bar at bottom then it goes blab like an old projector with melting film shrinking down to a light spot them out. Now just dark. I can get a few vertical steaks if I fiddle with pulling ribbon cable to the T-con.
So I think it's a bad t-con. I don't have a service manual to troubleshoot deeper.
Can you please help me be more certain?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Hi
Check if there is voltage on F101 on the tcon board.
Did you try other input signal types e.g. HDMI, AV, RF etc, you never said?
完成的
@jayeff
Hi Jayeff.
Thank you. I’ll look at that.
Also, sources don’t affect anything and I don’t get any menu or guide.
Do you have a service manual you can share? I could pay you a part of what it cost you.
完成的
@jayeff finally found f101. I can’t see which is the exact test point. With the cables going to the panel pulled there is 35v (half the 70v that’s supposed to be at f101) on the tp right next to it.
I notice there is oil from the foam heat sinks seeped into the ribbon connecting tcon to panel. I’m going to clean with electronics cleaner or methanol and report.
完成的
I cleaned all the oil from the heat sink compound and no blessing. Still no image.
Not sure where the voltages are supposed to be connected to. Chassis ground is obvious.
完成的
@Torin Finver
I don't think that there should be 70V on the fuse. That's just the fuse rating so that it can handle the current.
The test was only to see if the tcon was getting power or not.
I always test the chassis earth when testing for voltages as there is no other reference point
完成的
显示更多的2条评论
添加一条评论
1个答案
最有帮助的答案
Hi,
I don't have one but here's a link where you can buy one. (USB drive is the cheapest option)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Torin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 80
