NES colors too pale
I got myself an NES some time ago from ebay and tested it now. The problem in general is, that the color palette is really pale and you can hardly read any text ingame like that. Does somebody know an solution to that or even why the problem occurs? I already tried the method with the two games in the slot, but to no avail.
Here are some photos to compare to the originals
Have you replaced the capacitors?
由 Andrew S 完成的
@andrewsawesome No, I haven't replaced the capacitors. Can they cause this problem?
由 Meddllover 完成的
@meddllover I'm not sure, but I do know that 20-year and older capacitors are likely to be out of spec, which can cause weird faults. Are you using RF or component output?
由 Andrew S 完成的
@andrewsawesome I am using component output. Sadly I can't test it on my old crt, cause the RF there is broken.
由 Meddllover 完成的
