跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
Black screen + fans at a max
Hi,
If anyone can help me with a Macbook Air (2012, 5,2) please
I turn it on, no startup chime, just black screen and fans ramping up. Then somehow, after numerous restarts, and various key combinations, I managed to get into recovery and got it to instal Lion. Everything was running great.
Turned it off for the day, next day, the same thing, black screen and fans at a max. What is causing this and what can be done? Please help.
things I tried with no success:
- SMC reset
- PRAM reset
- plugged an external monitor
- Safe mode
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
So if I’m understanding this correctly,
One of the thermal sensors is absent causing the fans to be at maximum speed.
try holding a light up to the display (with it on) and see if there's anything there,
If you can’t fix it I can take a look, and try to fix it,
Or I could buy it off you.
Good Luck!
这个答案有帮助吗?
得分 0
2条评论:
Hey @beanman56, thank you for taking the time to reply. Don't know if it's the sensor, I could run it normally when I installed Lion which took a couple of hours, if it was overheating it would shut down I assume. When I turned it on the next day, it was black screen + fans at a max.
完成的
Sounds like a CPU problem, Most likely from overheating, which requires a new logic board, I can buy it off you if want, replacing the logic board is difficult, I could fix it for you though. For low price
完成的
添加一条评论
添加你的答案
JaxN3 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 79
